Can i replace/add a cellphone battery to my mp4player?
Old 13th Jun 2008, 5:03 pm
Default Can i replace/add a cellphone battery to my mp4player?
Cellphone batteries have the same voltage (3.7v) as the ones on mp4players. so no worries there. Cellphone batteries also have 800 mAH and higher.
The only thing keeping me from adding the battery is the thought of charging the battery. Will the mp4player charge then Cellphone battery without problems?
This is the one i plan to use:
Old 14th Jun 2008, 7:14 pm
yes u can :d
batterie MP4 is BL-4C and the batterie of Nokia for exemple is Bl-5C but the two battries have the same voltage is 3.7 so nothing dangerous
i'm using MP4 player with cell phone Batterie
Old 27th Jun 2008, 3:27 am
Did you remove the old battery or just tapped the New one with the old one?
My limited electrical knowledge tells me to remove the old one becuase it only has 240+ mAh. while the cell battery has over 800mAh. So i think it would be bad to use both...
Are my assumptions correct?
How to replace or fix a battery dimples78 Support and How To 3 5th Mar 2008 1:53 am
replace battery willyhehe92 General Discussion 35 5th Sep 2007 8:50 pm
How do you replace the battery? mpxguy Support and How To 1 29th Aug 2007 8:28 pm
Battery replace koschris Mods and Themes 1 25th Feb 2007 11:08 pm
replace battery wlazio2000 General Discussion 2 30th Dec 2006 10:50 pm
