searching a firmware and a help for mod my mp4 player
Old 7th Jul 2008, 2:40 am
Default searching a firmware and a help for mod my mp4 player
Hi, I' m new in this forum, i'm searching a firmware and a help for mod my mp4 player,
Can you say me where I can go for mod this?
Old 7th Jul 2008, 11:32 am
you will need original firmware
these players are many that look aloke BUT ARE NOT
do not betempted to upgrade to a firmware from a player that looks the same, it IS NOT
YOU WILL BREAK YOUR PLAYER
please do not upgrade, ask your seller for original firmware to start modding
Old 8th Jul 2008, 2:02 am
I think the player have the original firmware installed, why I ask the seller for give me? :roll:
Old 8th Jul 2008, 3:28 am
As makd511 says,
If this player isnt broken, dont try to fix it as there is every chance you will break it.
I have had 6 of these players now and barring the odd small bug, everything works fine.
Not even sure you can Mod these anyway, even if you find the correct firmware you cannot change anything.
Old 8th Jul 2008, 3:32 am
I also have another player with the next Rockchip up installed (yours is also rockchip but not the new chip), you can mod these new ones and extract the firmware but not yours Im afraid.
Old 8th Jul 2008, 4:08 am
ok, thanks for the answers,
If i don't mod this the player is good anyway?
There aren't bugs?
One of you have this?
Sorry i' m bad at english
Dead Player searching for the right firmware QuiGonJinn37 Dead Players 8 24th Jan 2009 1:18 am
Searching for a MP4 player victoriasmith General Discussion 1 9th Apr 2008 5:47 am
Searching For Drivers for my MP3 Player...? bigbear1460 Support and How To 0 5th Apr 2008 2:27 pm
Searching correct Firmware... doener_mann Dead Players 4 2nd Dec 2007 5:43 am
Searching for firmware to mp3 corifey Dead Players 0 14th Feb 2007 1:57 am
