charging with pc problem
Old 11th Jul 2008, 8:51 pm
Default charging with pc problem
hi there everyone. this is my first post here and to tell you i'm very desperate now.. here hoes the problem: i bought this 1 gb mp4 player from a
mall in our place. first it seems to be fine when my brother accidentaly tinkered with it and upgraded wrong firmware.. now i tried the recovery thingy and it did revived my player but now the start screen shows uxcell and the menu is a little bit larger than the screen, and when i try to charge it to my pc, when you press the menu it says "low battery", even if i already charge it for a couple of hours.. guys, i really need some help, thanks in advance
Old 17th Jul 2008, 1:39 pm
Hi darkzer0,
Have you ever had any problems with "low battery" before the upgrade?
Some possible suggestions:
1. Try using ANOTHER USB cable. Perhaps the cable is faulty with one or two pins being faulty...?
2. It could be that the USB connector on the player might have been faulty or damaged during your recovery process.
Hope that helps.
Mp4 Charging problem nin0gabriel Dead Players 1 21st Feb 2009 2:41 am
Video watch usb charging/starting problem madgamepro Support and How To 0 1st Apr 2008 12:35 pm
Charging problem spyrex Support and How To 1 26th Apr 2007 9:36 am
Charging Problem port3460 Support and How To 8 3rd Apr 2007 8:33 am
Charging problem with MP4 player Brett92 Support and How To 22 24th Mar 2007 1:37 am
