how to extract firmware from rockchip player?
Old 12th Jul 2008, 10:57 pm
Default how to extract firmware from rockchip player?
please... i need to guide about how to extract rockchip firmware or rockchip firmware extractor.
is it impossible? how can i find rockchip firmware extractor??
help me!! ㅠ_ㅠ
Old 13th Jul 2008, 12:21 am
what player, not possible with older rockchip players, but i with newer rk2706 chips
pics, model etc ..
ACTUAL PICS not ebay pics cheers
Old 13th Jul 2008, 12:32 am
Default Re: how to extract firmware from rockchip player?
My player is vx747
Old 13th Jul 2008, 5:01 am
right
you say its a vx747, but is it an original vx747 or the rockchip verison
if it is the rockchip version then we can extract the files for the firmware very easily which will allow you to mod the player also very easily to if you desire
i imagine you do hve the rockchip version so try this
download and copy this file to the root of the main players flash memory
disconnect and shut down the player
plug player back in again
you will now see another new dirve appear , 60meg in size and a load of files on it, these files are the firmware DO NOT DELETE THEM
copy them to your pc and you now have a backup should anything go wrng
also on the player main memory are there any files called a nae ending in RKW, if so this is the firmware file also, it is a packaged up version of all the fiels on the 60 meg partition
Old 13th Jul 2008, 6:04 am
thanks for posting reply. my vx747 is rockchip version. what does 'this file' mean? i can't understand.. is 'this file' what kind of program? where can i download?
Old 13th Jul 2008, 8:11 am
no program
the file is called
"rkusb.tag"
all you do is put it on your player main memory and disconnect and shut down the player
now plug the player back into the computer and you will see the new drive
there is no program for the computer needed to extract the firmware and no program needed to load the firmware
Old 13th Jul 2008, 8:32 am
sorry, i will post the file you need very soon
How do I extract firmware from my player louigi600 Support and How To 0 7th Dec 2009 6:13 am
How to extract the firmware of this MP4 Player? gnonide Support and How To 5 27th Apr 2009 6:59 am
How to extract RockChip 2608a firmware slavdodov Mods and Themes 0 2nd Mar 2009 7:00 am
How to extract a Rockchip firmware? gs1960 Support and How To 1 21st Apr 2007 12:06 am
Mp4 player cannot extract firmware katuga118 Mods and Themes 7 19th Jan 2007 11:07 am
