PRoblem with mp5 player rockship
Hello !
I bought a mp5 player on ebay: --> http://cgi.befr.ebay.be/ws/eBayISAPI...m=150273843296 but i don't find the firmware and the switch off doesn't work When the player is connected with the computer, I have 2 disk: the first --> i have formated the second --> i can't go in can you help me please ? |
the switch off oes not work, you mean it wont turn off, have you held the switch long enough
try holding power switch for 10-15 seconds to try and reset the player 2nd drive is the sd card slot, if no card in the player then you will not be able to access it |
Re: PRoblem with mp5 player rockship
thanks for your answers :)
for the switch off, i ask a switch off auto next 3 min. I turn on and that work For the firmware, how I find it ? |
These unbranded don't have firmware "upgrades" as such, like the big name brands do.
But the existing firmware can be easily extracted as a backup, in fact it is a good idea to do so., then you have a firmware that you know works in case you need to restore your player or if you want to mod it. All you need is here:- http://www.mympxplayer.org/firmware-...s-vt10856.html To upload your extracted firmware go to this page:- http://www.mympxplayer.org/dload.php (you will need to be logged in) Then click on the drop down "Select a category", scroll down to "uploads by members" and press enter, then at the top of the screen you will see an "Upload" button, then just click on it to go to the upload screen, and please remember to include a photo of your player. |
I extract the firmware
thanks for your help ;) |
| All times are GMT -7. The time now is 7:29 pm. |
