Mp4 Onda clone battery problem
Hi, I recently bought a fake Onda clone off an auction, the Onda clone worked surprisingly well, there were small tid bits of problems such as the reset button falling off and the player freezing up whenever I tried listening to Mp3s on the player (It would usually unfreeze after 20 minutes or so)
However, a friend of mine accidentally dropped the player and the red wiring connecting from the battery had disconnected from the motherboard of the player. I cannot find the correct place to re-solder the wire back onto the motherboard... and I figured this place could help. I suppose schematics of other rockchip Onda clones could help.. me find exactly where the wiring goes. Thanks in advance! |
| All times are GMT -7. The time now is 11:29 pm. |
