13th Aug 2008, 9:10 am
hi gvdgvdgvd
You need the consumerUpdate program from the downloads section.
If you do try the firmware there is a VERY HIGH you will KILL your player, but if you want to try and not worried by this then the choice is yours, but there will be NO going back.
BTW the Rkusb.tag is for the NEW Rockchip 27xx series players only, which are now the better and recommended players to buy.
Good Luck
knob
