PLS HELP -rockchip mp4
  #21 (permalink)
Old 21st Aug 2008, 3:46 am
Default Re: PLS HELP -rockchip mp4
Please keep us posted as i have the same player and I want to change the startup screen
  #22 (permalink)
Old 26th Aug 2008, 10:19 pm
Default PLS HELP -rockchip mp4 driver needed
I have the same player as in the picure. Just got it, I'm quite new at computers and gadgets so I didn't notice the windows 98 o the OS required. Is there anything I can do to make it read on my Vista OS? It needs drivers it says, and it won't even show up as a drive. - any help? Happy to have found this site...wish I had known more when shopping for one.
  #23 (permalink)
Old 31st Aug 2008, 6:50 pm
Anyone know if it possible to upgrade the this mp4 player http://jenniferhuang.en.ec21.com/pro...een_JD-212403_
  #24 (permalink)
Old 31st Aug 2008, 9:37 pm
sorry, there is no update for this player, if there is no name on the player, if it says ONDA you may be in luck, are you sure this is your payer, where buy from,
