Radio Function does not work
Old 5th Sep 2008, 5:35 am
Default Radio Function does not work
Hi, i bought a 2gb mp4 player but the radio funciotn does not work... when i choose this option the mp4 turns off and turns on automatically;
I'd like to know if i update the firmware will fix it. The firmware version is:
LSC_91N207H_A1
2008-03-07
9.1.52
2005-01-09
I download the versions bellow:
My Backup Firmware 9.1.52
2006/12/25
9.1.52
ACU7515
2007/01/01
(1.8", SR Sound, FM,
and
Full firmware: 9.1.52 for ACU7515
---[ info:afi ]------------------------------------------
file id = 'AFI '
vendor id = 0x10D6
product id = 0x1101
version = 9.1.52
date = 09/19/2007
Can I substitute my firmware using the downloads above? Will it work?
And how i do a backup of my firmware? I downloaded MP3 Player Utilities 4.15
Old 7th Sep 2008, 1:34 pm
Hi masterbusiness,
Has the Radio function ever worked? Generally MPx players need to have a radio receiver chip installed on the player for the Radio Function to work. So, even though the menu for "Radio" is there, if you don't have the chip installed on your player, it will not work.
Old 8th Sep 2008, 8:02 pm
Originally Posted by admin
Hi masterbusiness,
No, never. There is the option "Radio", but when i choose it, turns off and turns on. I think this is the problem.
Send it back is expensive (i'm from Brazil - Rio and i bought in China - Deal Extreme)
What i do friend?
Old 9th Sep 2008, 1:33 am
Hi masterbusiness,
What i do friend?
open a ticket with dealextreme, they are very good at sorting problems and are always willing to help in some way, they will refund the cairrage back in some cases, open a support ticket with them and see what is the best thing to do, i had defect stuff from them before and they just sent replacement and said not to bother sending back, also they have paid me back delivery cost as well, so speak to them, they are good
Old 9th Sep 2008, 1:36 am
masterbusiness,
Can you send us a link to your player? I want to check on the description of the player that it does have a radio function. If the product saids it should, then it should and it might just be a mistake in their manufacturing that they forgot to put in the FM transmitter chip on your player. However, it it doesn't say on the product page that your player has FM Radio, then it would be a mistake in their firmware and they should have removed the Radio option from your player's menu.
Old 9th Sep 2008, 7:36 am
Default Re: Radio Function does not work
The link: http://www.dealextreme.com/details.dx/sku.9372
I opened and the told me to send it back that they will send me a new one and pay $10 to shipping costs, but sending will cost to me $20, i don't know if is better to me 'cause is almost the value of the MP4 ($24,60)
Do you think it's better send it back or try fix it here, the cost to fix is between $20 - $40
Old 9th Sep 2008, 12:36 pm
The link you sent me said that it has "FM Radio" so it should have it.
So it seems it's a problem with the player.
You should COMPLAIN to them about this. They should pay for you to send it back though.
Did they suggest anything that you can do to try to fix the problem?
Question also, did you use the original earphones that come with your player?
Also, have you tried FORMATTING your player? First find out what file system it is using in Windows (whether it's FAT or FAT32) and FORMAT it. Most likely, it's in FAT.
Try formatting to see if that helps.
Old 9th Sep 2008, 1:09 pm
They told me they pay $10 to cover the cost i'll have with the shipment. But it'll cost me a double ($20)
They also told that i could try fix it here, but the cost to fix is between $20 and $40.
Yes, i used the original phones;
Yes i formatted but the problem is still there.
I don't know what i do because send it back and fix it is pratically the same, the little diference is the time they spend to send a new one
I don't know how to proceed, i'm afraid to spend money sending back and the problem happens again.
Old 10th Sep 2008, 1:41 am
Tell them about it and what about asking them for a PARTIAL REFUND?
Did you pay it for it using PayPal?
If you did, then you can file a dispute complaint about getting a product that wasn't as advertised.
Old 10th Sep 2008, 7:34 am
Yes, i paid using Paypal; I won't send it back, is not better to me. Actually i'd like at least a half of my money back.
I'll try talk to them about a parcial refund, that's a good idea. I don't know if they will accept this without sending the product back.
My 16GB MP5 Player/3.0" Touch FM radio does not work dingchow Support and How To 3 4th Jan 2009 5:20 am
Random function doesn't work how I want glowhand Support and How To 0 4th Oct 2006 11:31 am
radio doesn't work valvola Support and How To 3 14th Jul 2006 2:33 pm
E-book function? tasha Support and How To 1 19th Jun 2006 9:39 am
Next function pepe Support and How To 1 12th Jun 2006 5:14 am
