Cable for charging
Old 9th Sep 2008, 11:36 pm
Default Cable for charging
I have following player
file id = 0x0FF0AA55
vendor id = 0x10D6
product id = 0x1100
version = 3.5.35
date = 12/16/2005
info = 'SDK-ITEM/ACTION
manufacturer = 'Wilson
device name = 'S1 Mp3 P
usb attr = 'GENERIC'
usb ident = 'USB DISK D
usb rev = '1.00'
rtc rate = 0x3B6
display contrast = 11
light time = 0
standby time = 0
sleep time = 0
language = simple chine
replay mode = 0x00
online mode = 0x00
battery type = 1.5V alk
radio/fm support = yes
Now i lost my cable for charging. Somebody how knows where i can get one? Its not a normal smal usb. It is a little bit smaler!
Old 10th Sep 2008, 1:39 am
Can you post a picture of the USB connection on your player? Then I can make some recommendations for you.
Old 10th Sep 2008, 3:37 am
Default Re: Cable for charging
Thank you for your fast reply.
I will take a phote when i am at home!
Old 10th Sep 2008, 6:01 am
Just from the sound of it, I would guess it's one of these.
New USB 2.0 Mini 4 PIN Data Cable for MP3 MP4 Player
The older chipods used these cables. You can find them on eBay, but you have to look.
2 GB Black Temptation Player
8) WHITE MEIZU M6 8GB
8)
Old 10th Sep 2008, 9:27 am
Originally Posted by booboo773";p=&quot View Post
Just from the sound of it, I would guess it's one of these. http://rover.ebay.com/rover/1/711-53...3Dp3286.c0.m14
That looks good. Sony Ericsson v600 usb cable is very near to that but it is little bit to wide.
Is this the same? --> New Mini 4 Pins USB 2.0 Data Cable for MP3 MP4 Player.
The picture is perfect, i can see the 2 guide lugs!
Took a phot but it is hard to take a picture of small things. Hope you can see what you need
http://img139.imageshack.us/img139/4609/img4303ob3.jpg
http://img76.imageshack.us/my.php?image=img4296va2.jpg
This is the player
http://img137.imageshack.us/my.php?image=img4300if8.jpg
2 more
http://img365.imageshack.us/img365/4008/img4325xu7.jpg
This is best one
Old 10th Sep 2008, 4:51 pm
Just from the sound of it, I would guess it's one of these. http://cgi.ebay.com/New-USB-2-0-Mini...d=p3286.c0.m14
Is this the same?
http://cgi.ebay.com/New-Mini-4-Pins-...ayphotohosting
This is the player
2 more
This is best one
http://img216.imageshack.us/my.php?image=img4324hx1.jpg
Yes, that is the same one. I have a Nano clone too, and that is the exact type of cable mine uses. Mine is almost identical to the photo of your player except mine says Volume on the bottom of the keypad.
8)
Old 10th Sep 2008, 11:37 pm
The picture you posted does not show the 2 guide lugs. So i was not sure if it is the same
Samsung yp-z5 USB data Cable//losing usb cable P@inKuler Support and How To 2 5th Feb 2009 1:38 pm
usb cable for mp4 eltocado Support and How To 3 13th Apr 2008 1:09 am
USB cable Zephyron Support and How To 3 9th Mar 2007 4:30 pm
Need a USB cable confused_mp4_owner General Discussion 8 9th Dec 2006 8:43 pm
usb cable pigdogboy Dead Players 0 6th Oct 2006 7:48 am
