I use 4Gb in my RK26xx players, but not all work and not SdHC type:-
http://www.mympxplayer.org/non-hc-4g...em-vt8874.html and they are not easy to find.. :? |
thanks for the reply. It helps me so much. Btw, may you give me any suggestion which mini SD that would works in this player?
The brand I used was Topram got it on ebay from taiwan
Re: PLS HELP ME FIND MWALKER FIRMWARE (Rockchip)
well, recently i explored inside my mp4 player...(means that i opened the screw and........)
i found nothing like numbers that can be used as reference to find correct firmware....... (sorry for my bad english. I'm from asia > Malaysia) |
zedyll
Is your player DEAD? safest to leave it alone if it's still working. Only player I can think of that looks the same is Pasen A8, but it's firmware will probably BRICK the WALKER BL367, YOU HAVE BEEN WARNED! http://www.pasen.it/default.php |
THANKS ALOT KNOB!! IT iS SAME AS MINE (except for the brand)
recently my mp4 keypads KO. So, i repaired it by myself. HAHA repaired...
WARRANTY CARD > IN THE DUSTBIN |
I saw this post and i'm thinking if that firmware compatible with my mp4? when i check mines > ver: 00.00.0001 date: 2008-03-05 |
| All times are GMT -7. The time now is 7:49 pm. |
