PLS HELP ME FIND MWALKER FIRMWARE (Rockchip)
Old 8th Oct 2008, 1:14 pm
I use 4Gb in my RK26xx players, but not all work and not SdHC type:-
http://www.mympxplayer.org/non-hc-4g...em-vt8874.html
and they are not easy to find.. :?
Old 9th Oct 2008, 6:21 am
thanks for the reply. It helps me so much. Btw, may you give me any suggestion which mini SD that would works in this player?
Old 9th Oct 2008, 9:33 am
The brand I used was Topram got it on ebay from taiwan
Old 25th Oct 2008, 10:29 pm
Default Re: PLS HELP ME FIND MWALKER FIRMWARE (Rockchip)
well, recently i explored inside my mp4 player...(means that i opened the screw and........)
i found nothing like numbers that can be used as reference to find correct firmware.......
(sorry for my bad english. I'm from asia > Malaysia)
Old 26th Oct 2008, 1:14 am
zedyll
Is your player DEAD? safest to leave it alone if it's still working.
Only player I can think of that looks the same is Pasen A8, but it's firmware will probably BRICK the WALKER BL367, YOU HAVE BEEN WARNED!
http://www.pasen.it/default.php
  #16 (permalink)
Old 27th Oct 2008, 4:05 am
THANKS ALOT KNOB!! IT iS SAME AS MINE (except for the brand)
  #17 (permalink)
Old 27th Oct 2008, 4:16 am
  #18 (permalink)
Old 27th Oct 2008, 4:22 am
recently my mp4 keypads KO. So, i repaired it by myself. HAHA repaired...
WARRANTY CARD > IN THE DUSTBIN
  #19 (permalink)
Old 27th Oct 2008, 5:15 am
ShootNik
Posted: Fri May 04, 2007 12:47 pm Post subject:
How update firmware?
RockChip Firmware writer (http://www.sendspace.com/file/0yzzen) say error on all firmware posted in this thread...
My MP4 RockChip2606A (ver: 00.00.0010 Date:2007-01-16) descrise memory from 1G to 208M and don't receive file >3Mb, if I do - say disk not formatted.
Anybody have setup_consumerupdate.exe?
Or may player have combine_keys to format memory?
Help please...and sorry for my english.
I saw this post and i'm thinking if that firmware compatible with my mp4?
when i check mines > ver: 00.00.0001
date: 2008-03-05
RockChip 26 - error: Cannot copy or find the specified file burntorange Support and How To 4 28th Oct 2009 6:28 pm
How To> Find out wich Rockchip? Tokuma Support and How To 12 8th Feb 2009 11:04 pm
[SOLVED] HELP find hidden partition RockChip RK2706 mac_gyver Dead Players 9 16th Jan 2009 5:38 pm
need firmware for MWalker BL335 momoi Dead Players 0 17th Oct 2007 7:20 am
help me to find the firmware for my mp4 please pablo.educa Dead Players 0 18th Nov 2006 9:49 am
