-   -   Help on how to install RK2706 MP5 3.0" Firmware (http://mympx.org/forum/support-how/42208-help-how-install-rk2706-mp5-3-0-firmware.html)
knob 19th Sep 2008 11:23 pm
Another idea, if you don't want to return the player, upload the firmware you extracted somewhere like megaupload (not this site in case it is faulty) and I'll test it for you.
If it WORKS on mine then you have a HARDWARE fault and you can try and return the player to the seller.
