Can't read subfolders within the "audio" folder
Old 27th Sep 2008, 9:15 pm
Default Can't read subfolders within the "audio" folder
Good Pm
thanks to this site i was able to do much on my older ipod nano clone player especialy ont he video conversion part.
i had this new mp4 player i bought which looks exactly as this one:
http://www.rihey.cc/MP5-player/MP5-2...rs-2GB-K30.htm
but mine is labaled SONY(without model number or any identification anywhere) i just want to know if what firmware(hacked or better one) i can use on this. also i want to check if im a victim of "memory hack" but i cant seem to use the "mp3 player disk tool" on it. so anyone can point out other ways to check if this is a memory hack?
now since this is still in warranty, i cant open it up to see the board make. i have to wait for a month
but my real concern now is if anyone can help about its audio player or the player itself. becuase i usually categorize my music by putting them into different folders. but this players seems only to read music files under "audio" folder on its memory. i try to put my other folders into "audio" and even on the "root" but i cant browse to those folders. i can only see those songs in "audio" folder.
if someone can help, much better. hack firmware, or shortcuts i dont know of etc etc
thanks...
Old 28th Sep 2008, 2:58 pm
Default Re: Can't read subfolders within the "audio" folde
after much research about my mp4-player, i discovered that this unit has a chipset "SUNPLUS SPMP3052A".
ive tried to look for the same model for firmware but i cant find any. i got another mp4 player from a friend, kinda the same look, has the same menu structure and all. but i noticed that his unit is able to charge tru USB, but mine doesnt.
if anyone has the same unit, with better or hacked firmware i would like to have a copy pls. if theres a way for the music explorer to browse folders, then much better...
thanks
" Read or write device information failed!" wlazio2000 Dead Players 11 4th Apr 2009 5:41 am
Only takes songs from ONE FOLDER, subfolders ignored taleylon Support and How To 1 18th Apr 2008 7:53 pm
music folder says "empty disk" aviary17 Support and How To 3 30th Sep 2007 7:50 pm
"Read or Write device information failed" serp Dead Players 22 8th Aug 2007 12:57 am
Can't access "local folder" in music yougetwhatyoupayfor Support and How To 9 16th Apr 2007 5:09 pm
