Opening and replacing battery
Old 12th Oct 2008, 2:42 am
Default Opening and replacing battery
Hi,
I have a "patrick mp4 player", which looks exactly like this:
http://www.mympxplayer.org/album_pic.php?pic_id=581
I need to replace my battery, because it lasts 30 minutes and after 5 minutes of charging it seys that's full.
Anybody knows how to open the device? The case is like the one linked before, not two shell pieces, but a single one. Do I hjave to unscrew on th top or on the bottom? Any photo-guide?
Second question: which kind of battery should I buy?
Thanx a lot
Old 12th Oct 2008, 4:14 am
do you charge it for longer than 5 mins, because the battery indicator in the player is not set right
have you charged it for 2-3 hours regardless of what the indicator says
Old 12th Oct 2008, 6:24 am
Of course I did, but I'm not sure the charging operation to continue if indicator is says full anyway.
Old 12th Oct 2008, 9:58 am
Default Re: Opening and replacing battery
Uxcell have got loads of batteries:-
http://www.uxcell.com/batteries-c-981_1613_1622.html
there are some on ebay too, you need to check the size to be sure it will fit in your player.
Old 12th Oct 2008, 11:32 am
thanx a lot. Any idea about opening the case?
Old 12th Oct 2008, 1:01 pm
Have a look here:-
http://www.mympxplayer.org/viewtopic.php?p=9972
Replacing to all new firmware kingmax General Discussion 1 25th May 2009 3:59 pm
Need help replacing battery... DeltaFX Support and How To 7 30th Nov 2007 8:36 am
Replacing the battery in my Full Metal Platinum (2gen Nano) michiganjfrog Support and How To 9 7th Mar 2007 9:12 am
Replacing Battery cv1 Support and How To 4 22nd Dec 2006 5:15 pm
Broken screen, needs replacing myschyf Support and How To 4 22nd Nov 2006 6:34 pm
