Battery Replacement?
Old 20th Oct 2008, 3:26 pm
Default Battery Replacement?
Ok so my battery wouldn't hold a charge for more than a hour (says fully charged and then dies within an hour) so i decided to replace it. I purchased a battery off of ebay thats 1100mah and 3.7v. I'm guessing that the mahs are higher then the original cheap battery that came with it but the voltage is still the same at 3.7v.
Ok so heres my questions.
Battery: 3.7v 1100mah
Charger: 5.2v 400-500ma
Can i still use my USB charger to charge this battery? Will it take longer to charge? Will it charge the battery to the maximum charge? Will it harm the battery in any way?
Old 21st Oct 2008, 2:30 am
my experience with my mp5 wich is died and buried,
the symptômes of your player seem to be the same as mine, i still use my mp5 without battery,i branch it directly in my charger to power it ,when i finish seein movie for exemple i unplug,but one day i want to restore my battery then my mp5 was died, black screen for ever.
someone told me that he had replaced one chip by a diode,but i didnt try it
Old 21st Oct 2008, 9:06 am
I think the only problem with my player is the battery. I took a cell phone battery an rigged it up to test it and it stays charged and works fine. My problem is the charging of the new battery. I have had it on charge for 24 hours now. Yes 24 hours. It seems to be averaging a bar every 10-12 hours. Its just charging really really slow. I went to amazon and ordered a new USB charger thats 1000mah which means it should charge faster now.
Old 23rd Oct 2008, 9:43 am
Default Re: Battery Replacement?
For Actions chipset, charging circuit is calibrated to the original battery and so will limit the charging current to safe level for the original battery. Other chipset should be similar.
Charging Lion battery at higher than its maximum safe current will cause fire/explosion.
500mA is more than enough already. Lion battery should not be charged above 0.8C, most charging circuit in MP4 charge at around 0.5C or less to prolong battery life.
Old 23rd Oct 2008, 4:31 pm
Ok so is that why i can't get the 3rd bar on my battery when i charge it? I have tried 3 batteries so far and i've tried different chargers but im not able to get the 3rd bar on the battery.
Speaker Replacement? ALP1987 Support and How To 4 9th Jan 2009 9:58 pm
where to buy replacement battery? barnbug1 Support and How To 1 1st Jan 2008 12:06 am
Nano battery replacement yngwie0001 Mods and Themes 1 18th Jan 2007 8:53 pm
Battery Replacement yngwie0001 Mods and Themes 3 16th Jan 2007 12:30 pm
replacement battery masfud Support and How To 2 27th Jun 2006 3:28 pm
