[solved] My Battery has expanded!!
Old 12th Nov 2008, 10:21 am
You should definitely NOT mess around with lithium based batteries, they can and will EXPLODE or CATCH FIRE if charged with too high of a voltage or for too long. Look at videos on Youtube if you don't believe me.
I often need to charge those separately from the devices they came from, but became worried when some of the older ones started to swell up, and after reading about the fire hazard when using improper methods for charging lithium batteries, i built myself a Li-ion charger circuit. That way i can still recharge any type of Li-Ion or Li-Po battery and recover old batteries that have been disabled by the safety circuit for getting too discharged while still being sure they aren't going to blow. If you do charge them, charge them the right way.
Old 12th Nov 2008, 7:51 pm
And the new one......
Works to perfection, YAY!!!
However i now think that the first one(with the bust battery) was second hand, becouse the new one is supposed to be the same but the firmware is different - different welcome and goodbye screen, more animations ect.
Old 13th Nov 2008, 2:26 am
Great to know you got a good replacement.
Old 23rd Mar 2009, 8:56 pm
Originally Posted by Th3_uN1Qu3";p=&quot View Post
i built myself a Li-ion charger circuit. ...
Hey, could you post a circuit diagram of the charger you built? I would like to do the same.
-freddy
Old 24th Mar 2009, 11:38 am
WIZARD's Avatar
Default Re: Help with Mp4 player battery
Maybe because my battery isn't Chinese,
I don't know where it was manufactured.
However, even after these start-stop cycles,
the battery is really weak, and can stay for 2-3 hours at max.
Try to play !
  #16 (permalink)
Old 28th Mar 2009, 11:40 pm
Default Re: [solved] My Battery has expanded!!
Originally Posted by olivere_66";p=&quot View Post
I had my mp4 on my lap for about 5 minutes and my player expanded!! When i opened it at home the battery was twice it's normal width.
What do i do? Do i put it in the fridge, just leave it or deflate it (with a pin)?
Please help!!!
pictures to come.
Cheers
WOW, did you see your player expand while on your lap for 5 minutes?!! Phew, consider yourself lucky you didn't damage 'anything' else!
Glad you got the player replaced and with a better model one. Where did you buy it from by the way?
Also, what did the seller say about it and whether he gave an explanation to the problem?
[Solved] Desperately need help with battery recharge :( yenahs Support and How To 6 10th Aug 2007 6:11 am
[Solved] Battery become Big impeeza Support and How To 9 31st Jan 2007 10:19 pm
[solved] The battery is not charged full! Yusko Support and How To 5 30th Sep 2006 6:34 am
[Solved] Correct Battery rating prasanna Support and How To 2 29th Jun 2006 9:50 pm
