[solved] My Battery has expanded!!
Old 23rd Oct 2008, 8:46 pm
Default [solved] My Battery has expanded!!
I had my mp4 on my lap for about 5 minutes and my player expanded!! When i opened it at home the battery was twice it's normal width.
What do i do? Do i put it in the fridge, just leave it or deflate it (with a pin)?
Please help!!!
pictures to come.
Cheers
Old 24th Oct 2008, 1:35 am
oooh dangerous and needs replacing
send it back is the best bet
waiting for pics
this can happen occasionally, but its rare
Old 24th Oct 2008, 12:16 pm
Default Re: Help with Mp4 player battery
here they are
Old 27th Oct 2008, 9:25 am
You definitely need a new battery.
Remove the old one and put it in a fireproof container.
*carefully* puncture it outside to relieve pressure and explosion risk, away from anything that could catch fire.
Don't be too surprised if it does catch fire. Let it burn out, lion battery fires are very difficult to extinguish.
Old 27th Oct 2008, 1:30 pm
WIZARD's Avatar
No problem! :mrgreen:
I had the same thing with my mobile phone.
You can "resurrect" your battery
if you'll put your battery into player
and do this operation very fast :
"startcharging-stopcharging-start-stop-start-stop..."
After some cycles you'll see that
your battery is becoming OK. 8)
(But I don't know how to make
the normal size of the battery)
Try to play !
Old 27th Oct 2008, 1:31 pm
WIZARD's Avatar
And you can buy the extra battery in case.
Try to play !
Old 27th Oct 2008, 1:46 pm
Are you crazy!?!? Charging already swelled lion battery = EXPLOSION AND FIRE HAZARD!
Old 27th Oct 2008, 4:56 pm
it's fine guys, i'm sending it back and their sending out a new one!
Old 28th Oct 2008, 8:15 am
WIZARD's Avatar
As you see, I haven't harmed myself.
I just using this battery now...
And it's working! :mrgreen:
P.S. Maybe nothing happened with me
because I didn't know about this danger... :P
Try to play !
Old 29th Oct 2008, 7:24 am
WIZARD, are you out of you mind?! the lipo batteries are extremely dangerous types of batteries, they require a expensive circuit to make it safe and avoid the fire and explosion risk, but all these Chinese batteries doesn't have this circuits. search in youtube for batteries explodes and will see what can do.
remember several laptops sellers recall his batteries, do yo think they will lost so money if the risk is no so high.
[Solved] Desperately need help with battery recharge :( yenahs Support and How To 6 10th Aug 2007 6:11 am
[Solved] Battery become Big impeeza Support and How To 9 31st Jan 2007 10:19 pm
[solved] The battery is not charged full! Yusko Support and How To 5 30th Sep 2006 6:34 am
[Solved] Correct Battery rating prasanna Support and How To 2 29th Jun 2006 9:50 pm
