Funtwist Cinema 131 (Onda VX757+ clone). firmware etc.
Old 18th Nov 2008, 9:26 am
there is no hidden partition on the ingenics based player but you can customise the firmware as it is really easy, pop over to mp4nation and search for the tool to do the job in the onda forum, the firmare file is called an HXF file and there are tools to rip this apart an reveal all the image for you to replace and thn load back onto the player
Old 18th Nov 2008, 11:01 am
so easy... that's fine. ok, some of troubles solved. and that's only beginnin'
the things really madden me:
-uncustomizable equalizer
-txt-reader without any advanced settings
-no support of id3-lirycs
-uninformative "playing music" screen
-and listing keys (vol up, vol down) are... unlogicall. left scrolls down, right - up
-with such powerfull soc there's no dsp (like stereobase manipulations)
-fm list without channel-names
-font! i think times new roman is not a good choice
themes are just pictures and there's no problems with them. but is there solutions for other problems?
Old 18th Nov 2008, 12:54 pm
the problem is that chinachips that provide the solution firmware for this chip have been really bad in providing updates to the source, this is why onda and others are now not using this chip and are going over to rockchip processor instead and dumping ingenics/chiachip solution
all your complaints are common about these players using this chip
Old 18th Nov 2008, 1:52 pm
ok... i think topic might be closed
Old 18th Nov 2008, 2:11 pm
You can still have a play though, have a look here:- :wink:
http://www.mp4nation.net/forum/viewt...hp?f=24&t=2617
  #16 (permalink)
Old 19th Nov 2008, 7:35 am
Default Re: Funtwist Cinema 131 (Onda VX757+ clone). firmware etc.
A lot of the code is open-source, and Rockbox project is working on it.
The device can run Linux!
Need Firmware For my 2.8 TFT V1.1A ONDA Clone i think... Babyboy323 Firmware 4 25th Nov 2009 12:22 am
I feel such a fool - Dead RK2706 Onda vx757 Clone PSBlake Dead Players 3 26th Feb 2009 10:21 am
Unboxing+demo video from a Onda VX757 clone from Tinydeal Hotboxx General Discussion 5 2nd Oct 2008 4:42 pm
ONDA vx747 clone players ARE NOT ONDA but rockchip makd511 General Discussion 7 29th Aug 2008 8:44 pm
Onda VX757 Video review razzer001 Reviews 1 18th Apr 2008 8:08 am
