mp4 ipod dock with poor sound quality
Hi i got myself a ipod clone 4th gen with ipod dock the problem is sound quality is very poor in a docking station using ipod dock but great via jack connection is this right or should i get good sound using the dock connector?
Re: mp4 ipod dock
Bad connection to the dock connector.
I agree with lolita on the back dock connection. If it works great through the jack connection, then there's a problem with the dock connection as that's the only thing that's producing the poor sound quality.
Where did you buy it from and can you get it replaced under warranty? |
| All times are GMT -7. The time now is 3:13 pm. |
