-   -   Battery Wire deattached... (http://mympx.org/forum/support-how/42621-battery-wire-deattached.html)
zukipuu 21st Nov 2008 9:43 pm
I was trying to find the plate and screen numbers so I could download firmware, but when I was putting the screws back in, I realized the black wire on the battery was no longer attached to the board :( There's a picture at the bottom; can anyone tell me where I'm supposed to reattach the black wire? It's somewhere at the bottom around the red wire I think...
It's a fake iPod Nano 3G, it didn't even turn on for a few days and just a couple hours ago I was able to get it to show me an hourglass. If it's not too much trouble can anyone tell me what firmware I need, too?
Control: AK1025
Plate: G-18A_Main_V0.3 2007.09.08
Screen: LDH54124
http://img.photobucket.com/albums/v2...atterywire.jpg
lolita 21st Nov 2008 10:49 pm
Re: Battery Wire deattached...
See where the red one goes to a pad labeled B+? There should be another pad labeled B- or GND. Failing to find that, look for where there appears to be an empty pad with the broken stub of wire on it.
Also try looking in the Dead Players board, someone else has a G-18A there and might be able to provide more detail.
The firmware is this (seems to be an exact match):
http://www.s1fw.com/Firmware-1/G-18A...-IPODM-fw.html
zukipuu 23rd Nov 2008 8:36 pm
The B- was up in the top half, but I remember opening the back and seeing the black wire folded at the bottom with the red wire. It works now, though, thanks :)
