[HELP]How to find firmware or chipset info
Old 2nd Dec 2008, 1:17 pm
Default [HELP]How to find firmware or chipset info
Hello!
I've been searching for quite a while now, and can't find a way to know whose firmware or chipset my mp4 uses...
It definetely plays .mtv, but I can't make it work, because when i convert and play it, it just keeps blinkin a blue screen video player, but don't even play nothing. I'm pretty sure it isn't problem with conversion, because I tried many many combinations, with no success...
The info displayed at the firmware version screen is as follows:
FW:03.10.02
CHIP:08
It is a iPod [fake, of course] clone, with a microSD slot in the top, which I've put a 2gb Kingston memory in it...
I hope someone could please help me... I'm desperate..
Thanks!
Old 2nd Dec 2008, 4:52 pm
Default Re: [HELP]How to find firmware or chipset info
Open it up and read the part# off the chip.
Old 3rd Dec 2008, 3:34 am
I tried to do it once, but it's glued to the shell, so I can't dismantle it...
It plays, however, it can't play videos =/
Dunno what's going on?
Old 7th Dec 2008, 9:06 am
You want to download chip genius from here:
http://www.mympxplayer.org/tool-chip...-11-df883.html
This will tell you what the chip is at least :wink:
Old 7th Dec 2008, 5:44 pm
Post a picture of the interface and the menus.
Old 7th Dec 2008, 11:27 pm
Hi Jiizake,
So the only problem is that it doesn't play videos? If that's the case, then it's better to leave your player in tact and try to find out why your player doesn't play videos.
Does it come up with an error message such as "invalid file format" or "no files" messages?
The first thing to do is check for a SAMPLE VIDEO file, did it come with one?
Do you have a URL link to where you bought the player from?
Old 9th Dec 2008, 10:05 am
PsyBreaker
Thanks, mate!
lolita
Re.:
I'm not at home now, but I'll post similar mp4 interfaces, which probably will be of same
use as mine, since there is no unique record of any manufacturer...
Here they are:
This is like the one I got, but mine is marked "iPod", which, of course, it is not:
http://www.oficinadosbits.com.br/pro...mages/3823.jpg
This interface is just like my menu:
http://www.snetcommerce4.com.br/ecom...60715fs-69.jpg
Obs.: It have a microSD slot
admin
Hi Jiizake,
Re.:
Yes! It just doesn't plays the videos... but it doesn't show "invalid file format". Instead,
it just don't reads .amv, .wmv, .avi, .mpg and whatever you put in it, but plays (or tries
to do so) .mtv, which I've been testing with no success...
Of course, checking the sample video was one of my first thoughts, BUT I got my mp4 second
hand. Of course it's not very used, my friend who sold used from like 1 or 2 months, so no
sample video =(
As the place where it was bought, I asked my friend, and he got it from a shopping. No
success, though, because it closed... lol
As you can see, I'm in a bad situation... haha
Please, if someone can help me...
Thanks in advance ;D
Old 9th Dec 2008, 1:31 pm
It seems to be an older version of Actions player. If you post what Setup -> Firmware Info gives I can confirm whether or not it is.
MTV was the video format before AMV.
Old 10th Dec 2008, 11:31 am
It is already specified above, as:
FW:03.10.02
CHIP:08
There is no more info in the firmware menu, so...
Any guesses?
Old 11th Dec 2008, 7:46 pm
If it starts up with an hourglass it's a _very_ old Actions-based player, 2003 or 2002.
Need Info about my Firmware and MP4 jeng_jeng01 Firmware 0 13th Jan 2010 10:48 pm
How to find out my chipset!! spoony Support and How To 2 12th Oct 2008 11:15 am
Mp3 JVJ x8 chipset ATJ 2051H Broad EAG-599 help me find FW thehunterx10 Dead Players 0 11th Jun 2008 11:56 pm
Info about my mp3 player + firmware question xw0lf General Discussion 0 10th May 2008 12:01 pm
Help: Need to find out more info on this player. spidernz General Discussion 0 3rd Apr 2007 5:01 am
