-   -   Volume up button does not work (http://mympx.org/forum/support-how/42694-volume-up-button-does-not-work.html)
silence 5th Dec 2008 3:44 pm
hi my mp4 player is has a rockchip 2608a its the same from this page
Click here
well my problem is that the Volume up button does not work I even soldered in a new button clicky thing and still doesnt work I need help make this thing work. pls help
Oh yea thanks in advance :(
Th3_uN1Qu3 6th Dec 2008 3:05 am
If you are sure you soldered the new button in properly, the problem is somewhere else on the PCB. Follow the circuit traces of the button to the chipset and test for continuity with a multimeter. You should find the broken trace quickly.
admin 6th Dec 2008 3:35 am
Hi silence,
It seems to be a hardware problem than anything else (as you've already discovered). Question, is the player still under warranty? If it is, I would recommend getting it sorted under warranty.
The other option is to email dealextreme and ask them about the problem and what can done to fix. It's worth a try asking the question to see what happens, if you don't ask, you never know.
silence 6th Dec 2008 5:21 pm
thanks for responding my player doesnt have warranty anymore Ill try to find continuity with a multimeter. and Also Im going to ask on dealextreme, and see how else has had problem. I keep informing.
