files became invisible! need help.
Old 13th Dec 2008, 9:33 pm
Default files became invisible! need help.
while my mp4 is connected in my pc. it hangs (hour glass). then after i minute it resume working again and when i open it the files was gone!. i look at the files in my computer and its gone.
I look at the memory of my mp4. and its still contain the files because the size of the file used is still there.
please help me retreive the invisible files of my mp4 if can be done.
i thank you in advance.
Old 14th Dec 2008, 1:05 am
Hi BennyZars,
Can you play any of the files on your player? Do they all play ok or nothing?
What I suggest is to FORMAT the player. Try formatting it in Windows firstly to see if that helps the problem.
Player showing old files/songs. Have to keep repairing files eraldo Dead Players 9 4th Jul 2008 11:01 am
How can I extract 6 files (Not 4 files ) from sigmatel Ship tcomteck Dead Players 2 19th Mar 2008 4:10 pm
How can I extract 6 files (Not 4 files) from sigmatel ship? tcomteck Support and How To 0 13th Mar 2008 4:14 am
[solved] Files invisible to rockusb player TimBo Support and How To 3 15th Aug 2007 11:08 pm
Convert .mov files to .amv and playing amv files in mp3/mp4 kapias Video related 0 10th Jan 2007 9:40 pm
