How to Determine the Capacity of a Micron NAND Flash Chip
Old 21st Dec 2008, 9:51 pm
Default How to Determine the Capacity of a Micron NAND Flash Chip
After searching many google pages for the specifications of my hacked flash memory player I foud Micron's model numberig rubric here.
Remember that the capacity is expressed in bits, not bytes.
Old 23rd Dec 2008, 3:22 am
Default Re: How to Determine the Capacity of a Micron NAND Flash Chi
Most of the manufacturers use xG where x is the number of gigabits.
Samsung uses 1,2,4,8,A,B,C,D,...
Old 23rd Dec 2008, 12:16 pm
http://www.mympxplayer.org/nand-flas...ion-df644.html
Chinese MP5 flash memory capacity and part# nty General Discussion 0 28th Nov 2009 11:29 pm
Manufacturer of NAND Flash not be Supported gulego Dead Players 0 20th May 2008 2:55 pm
Samsung and Hynix Nand Flash Sizes and Serial Numbers tadad1 General Discussion 47 11th May 2008 6:20 am
Want to add nand flash card inside my ipod clone wekiller Support and How To 10 22nd Mar 2008 8:28 pm
NAND flash spyder559 General Discussion - Uxcell.com 0 1st Aug 2007 11:05 pm
