When connected to PC does not recognize it. Unknown device
Good!
fascilmil buy an iPod nano 3rd generation 8 GB Serial: 7M7367X6YOP; Model: ALL37 version: LSC_91N216H4_A2 2007-12-28 9.1.52 2005-01-09 when you connect to the PC does not recognize me or what the message is "unknown device" I've installed MP3 Utilities Disk Tool, but continuing with the same problem. if you have any response that would be great. Please I need help if you have any information or send answers to the following electronic address willortma@hotmail.com |
Hi willyman,
Have you done anything to your player before this problem happened or did it happen all of a sudden? Also, has it ALWAYS happened or just suddently? The three easiest things to try is: 1. Another USB port on your computer. Make sure you don't connect it to a USB hub as that probably won't have enough power to power your player as well as the hub. 2. Try another computer and see what happens. 3. Lastly, try a DIFFERENT USB CABLE instead. It has happened many times where the USB cable is faulty and produces this problem. Try those and let us know of the result. |
Re: When connected to PC does not recognize it. Unknown devi
Open it up and post CPU part#.
I did change usb ports on my WinXP computer and same problem. My Ubuntu Linux computer didn't recognize it either. |
Ok, I'm trying to get the back cover off and its not coming off very easily and I don't want to force it. It only has one screw on the bottom back left.
I have taken some pics as well, maybe that will help out. http://richieanderson.dyndns.org/misc/MP4/100_0604.jpg http://richieanderson.dyndns.org/misc/MP4/100_0605.jpg http://richieanderson.dyndns.org/misc/MP4/100_0606.jpg Thanks! |
Ok, the memory chip is HY27UU08AG5A
http://richieanderson.dyndns.org/misc/MP4/opened_up.jpg Thanks again! |
Anyone?
Did I ask for the part# of the flash chip? Follow the directions or we can't help.
anyway, i got my player working. i disabled the "Unknown Device" in device manager, then discoed/reconnected my player and windows recognized it as a USB Mass Storage Device, woo! I had to re-enable it, that messed it up again, but as soon as i discoed/reconnected again, it worked great! installed "iTunes Sync" so i can sync my music. maybe this will work for you too willyman. |
sage
READ the other threads here, if you did you would know what to expect inside and what the different parts are.
| All times are GMT -7. The time now is 3:40 am. |
