Noise Problem
Old 9th Jan 2009, 12:07 pm
Default Noise Problem
First of all, sorry for my bad english.
I buyed an MP5 player and I have a little problem . When I´m listeting to music or watching an AVI file, I can hear a little noise like a tiny wistle that does not stop. It makes my head hurts :cry: . I was thinking to upgrade the firmware and check if the noise stop....
My MP5 Chip ID is: RK2706 and Firmware Version: 2.19
Old 9th Jan 2009, 12:36 pm
Default Re: Noise Problem
There are some firmwares for players like this in the download section.
but don't even think about it until you have made a backup of the firmware you got already:-
http://mympxplayer.org/1-vt10856.html?start=0
Old 9th Jan 2009, 1:15 pm
Hi, and thank you for your respond. I saw the tutorial. I will do it but I don't know how to do a BackUp of my Firmware. I use Linux, not Windows... and I have a really good program that show the partitions of everything and I don't see the 60MB partition:
Old 9th Jan 2009, 1:39 pm
It works on linux too, I've tried it out but you need new Linux kernel v2.6.27 and you still need to copy RKusb.tag on to your player.
Old 9th Jan 2009, 2:32 pm
Thanks... I tought that I did not need that file on Linux using the Gparted... Now I can see the partition with the files on it. I´ve already did 2 backups like you said in the tutorial. Now I need a Firmware that can work with this MP5 player. I really dont know much about it. What firmware can my mp5 player use?
I wish to upgrade my Firmware so I can test if the noise is gone.
Edit:
One last thing... When I decied to put other firmware in my MP5... I have to delete the one I have and copy the new firmware folder to the MP5, and thats it?
Old 9th Jan 2009, 4:01 pm
Changing the firmware will do nothing to stop the noise. The DAC inside the player is faulty, you should send it back and get a replacement.
Old 9th Jan 2009, 4:33 pm
OK... I do that. Should I request a New Replacement or a Full Refound? .... what do you think? This MP5 are really good?
Old 10th Jan 2009, 7:35 am
Rockchip players are pretty good, you should request a replacement one.
Static buzzing noise that never goes away eello123 Support and How To 5 4th Sep 2007 9:07 pm
MP4 Background Noise Darklink Support and How To 5 31st Aug 2007 10:36 pm
Noise with new mp3 player karletto66 General Discussion 4 27th Oct 2006 10:57 pm
BZZZ noise Ruggenet General Discussion 7 17th Sep 2006 1:56 am
FM Transmissor - Pitch Noise Problem guivarrichio Support and How To 4 22nd Jul 2006 4:48 am
