I am on my second MP4 player the first was DOA and had to go through paypal to get a refund dead beat seller. So what did I do I bought a higher priced model from a local seller on Ebay and what did I get???
This player powers up plays the demos on the unit sound is great Radio works well too. but when I plug it into my PC to upload I have a problem, it recognizes the unit instals the rock chip drivers even sees the removable disk port. Here comes the bad part it will not copy files I get an error saying the path can not be found, when I look at the properties in my computer it shows no files and it shows 0 memory used and 0 memory available. I does show up in control panel Device manager and seems to be running OK now yellow flags atleast.
Now I am using and Pentium 4 with Windows XP home and my Duo core Windows XP Laptop and the same on both. Have I done something wrong or did I just get another more expensive paper weight?? any help would be appreciated.
I hooked to the USB ports on the back of the computers not sure but I believe both run 2.0 ports only.
I do see Files on the screen of the player but are not viewable on the PC's. Also I tried a cable for my Camera which had the same connections No Dice nothing.
more info on the unit
Prod name RK27SDK
Major version ID 1.1
Hardware ID 120124
local memory 0.034G (used)
3.878G (total)
I can not read anything on the disk with either the PC or Laptop
