Sound but no picture on TV output on MP5 player
Old 20th Jan 2009, 12:26 pm
Default Sound but no picture on TV output on MP5 player
Hi All
Newbie here, I hope you guy's can help me, kids are gonna kill me if I don't get this to work. Got an MP5 player off ebay ( no name probably a bad move on my part ) all working fine it is an 8g copied over a video plays no problem on player but when I hook it up to tv ( came with cables ) I can only get the sound. I imagine its like a Laptop to tv and you press the function key and external screen but how does this work on my MP5 player???? any help is apprietiated. BTW i have contacted the seller to ask the obvious. Also manual came with it but nothing about TV out.
Toe
Old 21st Jan 2009, 3:49 am
Default Re: Sound but no picture on TV output on MP5 player
Hi All
Seller came back to me in very broken english with this answer
"You must carry on the establishment first on MP5 PLAYER
Then connects on TV
The concrete establishment method, I will tell you"
Which makes no sense at all, I tried to google any of the above but nothing relevent to my poblem comes up.
Please anybody out there that can help will be doing a Dad a real favour.
Tony
Old 21st Jan 2009, 7:05 am
Ok it looks like there is no one with the same problem????
I have dug around and all I can find is a setting on the MP5 player that refers to TVsignal - PAL or NSTC
I have tried both ticked but still only sound blank screen.
Come on guy's dont let me loose faith in the Forum community.
Just a quick recap
I have an MP5 with TV out function, cable supplied plugged into tv start film on player but I get a blank screen.
Again any help or direction will help take this egg off my face.
Tony
Old 21st Jan 2009, 11:58 am
There is no sureity that every MP5 or MP4 which the TV-OUT function in its software also do the TV-OUT too.I have noticed many MP4 and MP5 players which have the option of TV-OUT but that didn't work acctually.But i can tell you the procdure that first you connect the TV-OUT cable to the MP4 and the TV and then switch the TV-OUT to PAL mode not the NTSC.I think that will help and yes another thing is that if you are using the DV option and making the movie from your MP4 and want to see it on the TV through the TV-OUT then try to make the movie in lower mode like (320X240) or something like that dont make the moviein high resolution.
Old 21st Jan 2009, 12:51 pm
Thanks for that Zulu
I was assured it had tvout funtions, it came with the cable and all.
Tried your fix but to no avail. Still only getting sound. If only there was a youtube demo or something.
If anything jogs your memory and you think of something please let me know.
Is there such a thing as a phone jack cable that ends with a hdmi
Would that help?
Tony
Old 22nd Jan 2009, 10:50 am
Can you post images of your player and where you are connecting it in your player? Can you also post a picture of the cable that you have? If it's just plugged into the earphone jack of your player, then you will only get sound. There must be a specific TV out jack point.
Also, do you have a link to the product you bought?
Old 22nd Jan 2009, 12:05 pm
Hi Admin
Here is the link to who and where I bought the MP5
http://cgi.ebay.ie/ws/eBayISAPI.dll?...m=350134138468
Only one hole which the ear phones go in so it looks like I have been sold a chocholate fire guard.
Given up the ghost on this and bought a Creative zen W. its the same ole story you get what you pay for.
Tony
Old 22nd Jan 2009, 2:07 pm
If it's just the earphone jack, then you will only get AUDIO unfortunately.
You need to get a Portable Media Player (PMP) insted for really good TV output but that's at a code. A lot of the MP4 players don't have TV output.
Old 22nd Jan 2009, 11:18 pm
oilburner2,
The link that you gave appears to be very similar to the mp5 "Convert Free 3" 16:9 screen wTV-Out" that I recently purchased.
It has the Ingenic JZ4725 CPU chip.
On my mp5, there is only one jack, which is used for both earphone and the TV-out cable.
To get TV-out to function, my mp5 has two settings in toolbox as follows:
TVOUT standard: (You select either PAL or NTSC)
TVOUT switch: (Off or Open)
You simply select the TV standard used in your country ( either PAL or NTSC) and set the switch to open.
The TV-out cable has the three RCA plugs which connect to your TV's video inputs (yellow is video; white and red are audio).
The other end of the TV-out cable plugs into the earphone jack.
Note that the mini-jack of the TV-Out cable has four conductors, not three like a normal earphone mini-plug. (see photo below)
Now when you connect the TV-Out cable, you should get the video as well as the audio.
Here is a pic of the TV-Out cable that came with my mp5 player.
Hope this helps you out.
Is your player a Rockchip or JZ4725 ?
To check, simply download the program ChipGenius v2.64 from this site and it will read the USB info, when you connect your player to your PC.
Cheers
Old 23rd Jan 2009, 3:44 am
Thanks Autofils
I have printed off your test and will try it tonight, I was sure I tried both PAL and NTSC but in the heat of the moment I might have tried the same one. Wish me luck.
I will let you know the firmware etc... and let you know how I get on.
Tony
MP5/PMP Sound output dewdude General Discussion 2 26th May 2009 5:50 am
AMV video problem: sound fine, picture distorted mamtoug Video related 1 20th Apr 2009 12:14 am
UniBit player sound output problem gmaster Miscellaneous 3 1st Sep 2007 4:35 pm
amv converter problem, i get sound but no picture bigm43 Video related 9 30th Sep 2006 11:59 pm
picture is bad and the sound is very weak Laske Video related 1 20th Sep 2006 4:44 am
