Help! My '16GB' player flash memory disappeared !!
Old 6th Sep 2010, 11:23 pm
my mp4 looks like yours?
what can i do for format it?
Old 7th Sep 2010, 11:22 am
You can test your player memory size with h2testw.exe which is free on the internet. It writes files to test the true memory size and reports.
Delete the files afterwards.
Gently push the reset (hole) with a straight paper clip to get back to normal. Off and back on should format it, or use regular XP/Vista format. It
does not affect the firmware.
16gb mp4 from ebay wont restore memory... panagath Support and How To 6 9th Apr 2009 2:56 am
How to flash memory my mp3 player mercury? gundam_exia Dead Players 2 19th Jan 2008 8:56 pm
Flash Memory usa6116 Dead Players 1 16th Aug 2007 11:19 pm
Osmium 1GB , 2'' mp4 player flash memory problem Zarko General Discussion - Uxcell.com 10 10th Jan 2007 6:45 am
adding more memory on your mp4 via flash memory, possible? jb_jonas Support and How To 1 18th May 2006 1:25 am
