[solved] Mini SD card not Read by my MP4
Old 31st Jan 2009, 10:12 pm
WOW!
What firmware did you use? Did it come with your player or did you extract it or download it from somewhere?
I haven't seen that solution before. Quite a big risk updating your player's firmware but I'm glad it's working!
Old 1st Feb 2009, 5:13 am
Hello please upload the firmware and let us know more about your mp4
upload link
http://www.mympxplayer.org/dload.php...load&cat_id=20
Old 1st Feb 2009, 8:36 pm
Default have same problem here ..
i've mp4 player alltronix AFE014N06 1 GB. i buy sdcard hc 4gb but i can't use it, it show card error. i've try to format with fat system but it still can't read. how to make it working? update firmware or something?? please help. thanks
Old 3rd Feb 2009, 4:39 am
ZILAN : DONT UPGRADE THE FIRMWARE !!!!!
Do you have a firmware wich came with the player on a CD or something ?
HAve you tried what we suggested UP in this topic ? Read all and let us know...
Old 4th Feb 2009, 3:06 am
@Groovy
why?
no i don't have firmware that came with my player.
i've tried format my sd hc to FAT System but still card error.
  #16 (permalink)
Old 4th Feb 2009, 4:41 am
zilan,
Using an incompatible firmware for your player will render your player DEAD. So as well as the memory card not working, you'll also have a dead player.
Have you tried another card?
What about trying a smaller capacity card like a 1GB or 512MB card to see if that works or not.
  #17 (permalink)
Old 5th Feb 2009, 5:36 am
thanks admin for ur answer ...
do u have compatible firmware for my mp4 player?
regarding to chip genius v2.64 my chipset is :
PnP Device ID: VID = 10D6 PID = 1101
Serial Number: A00000600001
Revision: 1.00/1.00
Device Type: Standard USB device - USB2.0 High-Speed
Chip Vendor: Actions
Chip Part-Number: ATJ209X/ACU75XX
my firmware version now is mp3 player BKSD1512_20 2007-06-01 9.1.51.
yes, i have tried another sd card and it's only works for 1GB. 2GB above doesn't work for my player.
i want to make my player support high capacity sd card ex 4 GB.
  #18 (permalink)
Old 5th Feb 2009, 6:49 am
you can not update the player, the firmwares were never developed and no way of knowing, either way, no support for these older chips beyond 2gb and no other firmware will give you this
sorry
[solved] Dead SD Card - card unreadable UzY3L Miscellaneous 2 19th Sep 2008 1:39 pm
what mini SD card can i use etchin_uk Support and How To 2 22nd Mar 2008 9:16 am
PLayer waon't read from memory card uneektyreek Miscellaneous 2 7th Feb 2008 6:16 pm
Anyone tried 4Gb mini SDHC on MP4 with Card reader? rodonn General Discussion 2 19th Aug 2007 8:04 am
My Mp4 doesnīt read Directories, WITHOUT A CARD. polako71 Support and How To 4 11th Mar 2007 1:13 pm
