[solved] Mini SD card not Read by my MP4
Old 29th Jan 2009, 7:01 pm
Default [solved] Mini SD card not Read by my MP4
I have an MP4 from a Chinese brand Ramos.Model RM600Le that supports Mini SD card upto 2GB.So I got a PNY Mini SD Card of 2GB for it, but the problem is that the MP4 does not read the card.Although it detects it but when I try to open it, it freezes for 5-10 seconds and then takes me to the contents of the flash memory.The memory card works fine when I insert it in the Memory card reader of my laptop.The player is basically a Rockchip.
Old 30th Jan 2009, 2:10 pm
Hello,
First - > Try if it works with another card ( borrow some from a friend )
If yes -> Sorry you gotta buy other
If not -> You better give it back to the seller
Old 30th Jan 2009, 11:20 pm
Isn't there any configuration to be made in the Memory Card like some formatting or creating a folder that the player reads?As I have seen in some other players.
Old 31st Jan 2009, 1:18 am
Default Re: Mini SD card not Read by my MP4
Hello!
I am not a professional, but the first thing I do with a purchased card, is to farmat it. Try it, I hope it will work!
Old 31st Jan 2009, 1:24 am
I would agree with the previous answers.
1. Try FORMATTING your card firstly.
2. Try a different card.
3. Try a LOWER capacity card such as a 512MB card instead. Some players can not detect large memory cards such as 2GB or 4GB cards.
Try that and let us know of the result.
Old 31st Jan 2009, 3:56 am
What File System Shall I use to format the Card?
FAT or FAT32?
Old 31st Jan 2009, 4:56 am
Depends on the size of it.
Newer players now should take FAT32 fine while the older ones will only work with FAT. Try FAT32 then FAT if it doesn't work .
Let us know how you get on.
Old 31st Jan 2009, 5:21 am
I have tried formatting the Card with both FAT and FAT32 but still the player does not read the card.Any other idea?
Old 31st Jan 2009, 12:33 pm
What memory size of your card?
Can you try a smaller size card instead? Such as 512MB or 1GB card? The smaller the better as some players will not recognise large capacity memory cards.
Old 31st Jan 2009, 7:47 pm
Hey guys just updated the Firmware of my MP4 and Miraculously The Card started working.Thanks for the help.
[solved] Dead SD Card - card unreadable UzY3L Miscellaneous 2 19th Sep 2008 1:39 pm
what mini SD card can i use etchin_uk Support and How To 2 22nd Mar 2008 9:16 am
PLayer waon't read from memory card uneektyreek Miscellaneous 2 7th Feb 2008 6:16 pm
Anyone tried 4Gb mini SDHC on MP4 with Card reader? rodonn General Discussion 2 19th Aug 2007 8:04 am
My Mp4 doesnīt read Directories, WITHOUT A CARD. polako71 Support and How To 4 11th Mar 2007 1:13 pm
