How to extract firmware 9.1.53
Old 10th Feb 2009, 9:56 am
MXP MXP is offline
Default How to extract firmware 9.1.53
How to extract firmware(9.1.53) of my player? s1fwx does`t dump((((
Old 11th Feb 2009, 10:25 pm
what does your player look like?
nano generation 2?
Old 12th Feb 2009, 3:08 am
MXP MXP is offline
nano generation 2?
look like that Click the image to open in full size.
s1clone and other dump programm`s don`t see flash memory in my mp3, what is the problem?
Old 12th Feb 2009, 5:35 pm
take this answer with a grain of salt:
Ive heard around the net that s1clone
does not work for any 9.xx series, and
the only thing to do is to wait for it to
support it.
Just hold on to your mp4, and maybe they
will have a breakthrough and finnaly find
a way to break through and get it, untill then,
theres nothing i can suggest
How can i extract its firmware.. any help? kimbz920 Support and How To 2 7th Dec 2008 1:54 am
How to extract 9.1.52 firmware nywww Support and How To 16 19th Mar 2008 6:16 am
Can You Extract A firmware 9.0.48 baistosh Support and How To 1 4th May 2007 8:40 pm
firmware extract??? Camaro Support and How To 1 5th Mar 2007 12:44 am
how do I extract my firmware or is it even possible? squall458 Support and How To 1 4th Mar 2007 10:35 pm
