My MP4 player charges for only 10 mins then battery gets low
Old 17th Feb 2009, 4:15 am
Default My MP4 player charges for only 10 mins then battery gets low
I bought an MP4 Player on which it was written SONY-Made in Japan.
I got a NOKIA charger with it. My MP4 gets charged with that charger but just after 10 minutes the battery gets low, even if I charge it for a day. What should I do?
This picture (click here) is like my mp4 but on my it is written SONY.
Old 17th Feb 2009, 4:21 am
Has this ALWAYS happened to your player or did this just started happening?
I would suggest try ANOTHER USB CABLE instead to see if that helps.
What if you plug your player into your computer through the USB, does that charge properly?
Old 19th Feb 2009, 5:42 am
NO!!
Old 19th Feb 2009, 12:29 pm
First of all brother you can't use the nokia charger with this MP4 coz if you continousely do that it will kill you MP4 coz the mp4 charger has the 5volts and this nokia has more then that.Secondly on your problem of not saving the charging well.... you need to change the battery of MP4,no body can do anyting on it just change the battery of your MP4.
Old 19th Feb 2009, 2:21 pm
Originally Posted by talha936";p=&quot View Post
NO!!
"No" to what question?
Old 21st Feb 2009, 7:42 am
NO!!
ya sir i am haveing same problem here can u pls tell how can repair i hv try many batter change but same problem
Old 22nd Feb 2009, 1:41 am
if the battery can survive 10 minutes then it can survive more time too if the battery is good.If it is not the battery problem then it shouldn't have to survive the 10 mintues too
Rockchip player only charges through USB on computer scorpion08 Support and How To 2 12th Jan 2009 1:04 pm
Windos XP won't recognise my player, only charges Flop Support and How To 16 4th Jan 2009 11:26 am
[solved] MP4 Player Only Charges via USB won't transfer Stevey Support and How To 2 12th Aug 2008 1:02 pm
Help: Battery only charges half way bigboy99 Support and How To 3 17th Dec 2006 12:50 pm
mp4 player charges and doesn't play Randy Rooster Support and How To 3 16th Jun 2006 4:57 pm
