Vidrop problems
Old 19th Feb 2009, 10:40 am
Default Vidrop problems
I placed a DVD in the computer and pressed DVD on the Vidrop and as described it converted the largest file on the DVD.When I tried to convert the other VOB files which I had moved to my documents for ease of access it would not convert.I got the message that M.Player had stopped working,along with a notice that a programme had reset the colour,also whilst trying to convert, a fail message came up in what looks like the DOS box saying repeatedly,"CRC failed".I thought it might have been the DVD but I tried another one and same problem.I uninstalled Vidrop and reinstalled but to no avail.I restarted windows,no luck.Finally I tried the web video downloader but nothing downloaded.I am able to convert family films of the AVI variety withy no problems.Help
Old 20th Feb 2009, 9:32 am
WIZARD's Avatar
Default Re: Vidrop problems
Maybe your two Vob files were both wrong.
After uninstalling, clean the registry and install again.
Try to play !
Old 20th Feb 2009, 11:21 am
tried this already,what is frustrating is that yesterday on 1st trying the software it worked brilliantlty just as described but the very next time I used it from the same DVD and others it no longer works
Old 20th Feb 2009, 1:50 pm
Afaik viDrop does not decrypt the DVD, is the DVD copy protected by any chance? or is it an home made DVD?
Old 21st Feb 2009, 3:24 am
When you say is the DVD protected does that mean I cant convert any DVD's ? If so what is the point of Vidrop.Also as I said when I inserted the DVD 1st time ,I hit the DVD buton on Vidrop and it converted the largest file.This converted file worked fantastically on my MP4.What I was then trying to do was convert the rest of the same DVD as it contains numerous music videos but I seem unable to do this.I guess I'm just a bit thick when it comes to computers
Old 21st Feb 2009, 4:13 am
I have just tried to convert a normal DVD movie and the vidrop started ok and half way through I got the message"mencoder.exe has stopped working"
Old 23rd Feb 2009, 8:24 am
Ive never used the DVD function before, but it you're saying it worked
"when I inserted the DVD 1st time ,I hit the DVD buton on Vidrop and it converted the largest file.This converted file worked fantastically on my MP4.What I was then trying to do was convert the rest of the same DVD as it contains numerous music videos but I seem unable to do this.I guess I'm just a bit thick when it comes to computers"
Im guessing viDrop can only convert the largest file and not any other files?
[solved] vidrop help 0nelegit Video related 7 27th Jul 2012 12:58 am
dvd subtitles with vidrop vernestre Video related 1 2nd Nov 2009 10:58 pm
sound off using vidrop v.055 lilo_goki Video related 3 8th Jan 2009 6:08 am
Help using ViDrop to convert leeboy Video related 4 28th Jan 2008 11:35 am
Please Help vidrop 0.53 cippo Video related 1 27th Dec 2007 11:56 pm
