-   -   Need help with an mp3 player (http://mympx.org/forum/support-how/43343-need-help-mp3-player.html)
BlueEyed 24th Feb 2009 8:16 am
I got this mp3 player I think its from like 06 or so. It was never used. When I went to install the firmware from the disk it just has for win98 and I have winxp and vitsa. Here is all the information I can find on it. HELP ME PLEASE!
This is the customized Windows host software for Sigmatel MSCNMMC Audio Player.
Firmware requirements for this host include:
SDK_Base_Version=SDK2.620 (3 resource.bin)
USB_Vendor_ID=066F
USB_Product_ID=8493
SCSI_Manufacturer="Sigmatel"
SCSI_Product="MSCNMMC"
MTP_Manufacturer=""
MTP_Product=""
The firmware binaries shipped with this host, if any, were used to test your host applications and drivers on SigmaTel development hardware. You must replace the SigmaTel binaries with your hardware-specific firmware for proper operation of your player.
The information for this player is as follows:
Date=12/4/2006 7:54:42 PM
Request_ID=9780
Host_Version=1.716.2.002
Product_Description="Sigmatel MSCNMMC Audio Player"
USB_Vendor_ID=066F
USB_Product_ID=8493
MTP_Manufacturer=""
MTP_Product=""
Company_Name="Sigmatel"
Copyright_String="Copyright (c) 2005, All rights reserved."
Updater_Title="Sigmatel MSCNMMC Firmware Download"
Default_Install_Folder="Sigmatel\MSCNMMC"
Start_Menu_Folder="Sigmatel MSCNMMC Audio Player"
Start_Menu_Updater_Shortcut="Sigmatel MSCNMMC Firmware Download"
Software_Registry_Location="Sigmatel\Sigmatel MSCNMMC Audio Player"
Background_Title="Sigmatel MSCNMMC Audio Player"
SPLASH_SCREEN_BMP=DEFAULT
ABOUT_SCREEN_ICON=DEFAULT
UPDATE_SCREEN_ICON=DEFAULT
SEARCH_DLG_AVI=DEFAULT
LICENSE_STRING="SigmaTel, Inc."
INSTALLER_GUID=0598b62c-ec66-4c2c-9351-815fe39cedac
Install_Updater=TRUE
Always_Reboot=FALSE
Run_Updater_After_Install=FALSE
Default_Format_Data_Area=FALSE
Default_Volume_Label="MSCNMMC"
Preferred_FAT=2
Hide_Chip_Version=FALSE
Allow_Auto_Recovery_Mode=TRUE
Always_Force_Recovery=FALSE
Has_Custom_Support=FALSE
Low_Nand=FALSE
Hide_Details_Button=FALSE
Force_Get_Current_Versions=FALSE
DriveArray={{"", L"", DriveTypeData, DRIVE_TAG_DATA, FALSE, 0},
{"bootmanager.sb", L"Boot Manager", DriveTypeSystem, DRIVE_TAG_BOOTMANAGER_S, TRUE, 0},
{"hostlink.sb", L"Host Link", DriveTypeSystem, DRIVE_TAG_HOSTLINK_S, TRUE, 0},
{"stmpsys.sb", L"Player", DriveTypeSystem, DRIVE_TAG_STMPSYS_S, TRUE, 0},
{"resource.bin", L"Player Resource", DriveTypeSystem, DRIVE_TAG_RESOURCE_BIN, TRUE, 0},
{"resource.bin", L"Player Resource 2", DriveTypeSystem, DRIVE_TAG_RESOURCE_BIN+0x10, TRUE, 0},
{"resource.bin", L"Player Resource 3", DriveTypeSystem, DRIVE_TAG_RESOURCE_BIN+0x20, TRUE, 0},
{"hostrsc.bin", L"Host Resource", DriveTypeSystem, DRIVE_TAG_HOSTRSC_BIN, TRUE, 0},
{"updater.sb", L"Updater", DriveTypeSystem, DRIVE_TAG_UPDATER_S, TRUE, 0}}
HISTORY
Host Version : 1.716.2.002
Submitted : 12/4/2006 7:54:42 PM
Request ID : 9780
Comment : sdk2620-fat32-mmc
Host Version : 1.716.2.001
Submitted : 12/4/2006 7:05:15 PM
Request ID : 9773
Comment : sdk2620-FAT32
AppName=Sigmatel MSCNMMC Audio Player
ProductGUID=0598b62c-ec66-4c2c-9351-815fe39cedac
ErrorReportURL=http://www.installshield.com/isetup/ProErrorCentral.asp?ErrorCode=%d : 0x%x&ErrorInfo=%s
MediaFormat=0
LogMode=1
Skin=setup.skin
Resource=_Setup.dll
SmallProgress=N
SplashTime=5
CheckMD5=N
CmdLine=
ShowPasswordDialog=N
[Languages]
Default=0x0009
count=10
key0=0x0804
key1=0x0404
key2=0x0009
key3=0x040c
key4=0x0007
key5=0x0011
key6=0x0012
key7=0x0416
key8=0x0816
key9=0x000a
RequireExactLangMatch=0x0804,0x0404
When I go to the start and go to where the app is and click on it. It dont bring up the firmware app. It brings up a screen saying Sigmatel MSCNMMC firmware download and under it.. Current firmware version has nothing... then it has upgrade frimware version 7265.6520.7072.....then show details when I click on that it says...
Unable to open bootmanager.sb firmware file then I click okay and it brings up another screen Firmware version details. Current version : Boot Manager 0.0.0 Host Link 0.0.0 Player 0.0.0 Player Resource 0.0.0 player Resource 2 0.0.0... Device Details: Chip Version 0...Upgrade version...Boot Manager 6520.6973.6972 C:\Program Files\Sigmatel\MSCNMMC\bootmanager.sb .. host Link 6520.6973.6972 C:\Program Files\Sigmatel\MSCNMMC\hostlink.sb .. Player 6520.6973.6972 C:\Program Files\Sigmatel\MSCNMMC\stmpsys.sb .. Player Resource 6520.6973.6972 C:\Program Files\Sigmatel\MSCNMMC\resource.bin .. Player Resouce 2 6520.6973.6972 C:\Program Files\Sigmatel\MSCNMMC\resource.bin
