HELP!!!How to use the CD that comes with my player.
Old 26th Feb 2009, 9:28 pm
Default HELP!!!How to use the CD that comes with my player.
Hello everyone!!!Im trying to recover my dead player.I searched for a firmware here but never find any.I had found a shaped cd on the bottom of my players case.I opened it and got this files inside the cd.
1.8 inch screen MP3 Driver(folder1)
-skin(folder)
-AMV_DecDLL.dll
-AMV_EncDLL.dll
-AMVCON~1.EXE
-amvplayer.exe
-AmvPlayer.ini
-AmvTransform.dll
-amvtransform.exe
-AmvTransform.ini
-movieconverttoolcn.chm
-movieconverttoolen.chm
-movieconverttooltw.chm
-read_me.rtf
-settings.ini
-tranmsg.txt
-transdll.dll
2.0H inch screen MP3 Driver(folder 2)
-InstMsiA.exe
-InstMsiW.exe
-MP3SET~1.EXE
-MSI.CAB
-Msicn.msi
-Msien.msi
-Msifr.msi
-Msige.msi
-Msiit.msi
-Msijp.msi
-Msiko.msi
-Msisp.msi
-Msitw.msi
-Setup.exe
-vcredist.exe
I dont seem to find any firmware here for my player.Can you help me what to do with this files?Are these files solutions to my dead player?
Thanks a lot!
Old 1st Mar 2009, 2:13 am
Folder 1 - That's just the converter software so no firmware there
Folder 2 - That also looks like the converter software as well.
Firmware files are in either .bin (Actions), .fw (Actions), .rfw (Rockchip) and there are the Sunplug ones but I can't remember the extensions on those at the moment. But look at what you have shown, none of those are firmware files.
Is there something wrong with your player?
Old 2nd Mar 2009, 4:04 pm
Thanks a lot admin.At last i really heard from you.Sad to hear there is no firmware on my cd :cry: Anyway, yes i have a problem with my player.It is dead now after loading songs and playing them it shows an hour glass with blue screen.I am able to make it recognize by my computer using the recovery guide and tried downloading firmware(the closest) but all i got is a white screen.I am always checking on new firmware but none worked for me :cry:
I found this numbers on my player:
(ON THE BACK)
hynix KOR
HY27UU08AGSM
TPCB 825HA
MTUJI047JQ
03C4110
AK1025
8F007AB0FB
SPT
SP3767AHN
08DT11
(I saw this in the front screen)
GOLZI
G-18A_MAIN_VO.6
2007.12.08
(and these one on the
upper side of the LCD)
XYXWO210807 06-B
Please if you know any firmware for me, i really need your help as i am so excited to use my player.I used it for only 1 day then it happened...
