help mp5 player
Old 5th Mar 2009, 2:32 am
Default help mp5 player
Unless, someone knows tell me this player with this menu that chip installed?
http://i277.photobucket.com/albums/k...g?t=1224968724
Old 5th Mar 2009, 3:28 am
Go into the [Setup] menu of your player.
Then choose "System Info" or "Firmware Info" and it should tell you the firmware version etc....
Post that and it will give us a better idea. Otherwise you can also open up your player and post the plate and board ID numbers which will help too.
Any reason why you are looking for the chip installed?
Old 5th Mar 2009, 4:25 am
If the menu looks like the picture it's a Rockchip RK27xx series.
Good idea to back up your firmware, look here:- http://mympxplayer.org/firmware-extr...s-vt10856.html
