Need conversion help please, new to PMP's
Old 9th Mar 2009, 1:14 pm
Have you tried contacting the seller about what format the video should be in? Ask them if they can also send you a sample file so you can see what the settings are for that file. That's the easiest way, that way you've got a good starting point.
I think you should really try Windows XP for the sake of the software to see if that makes a difference. Given your concerns about it, what about dual booting Win XP with your Win 98 but make sure you turn off your network card in Win XP instead so it doesn't connect to the net.
Old 9th Mar 2009, 5:17 pm
Default Re: Need conversion help please, new to PMP's
Ok, i have XP installed on a second boot drive running dual boot so i can enjoy both worlds. Vidrop works flawlessly and so does the aviconverter 5. something i dloaded from here. I can now take the vids and run them through an inspector and see what i need to do to make them work in 98 if i get the notion to. I had it so close i didn't realize it. I was not putting the audio into mpeg layer 1 (stereo) i was using mono because that is what the mp4 file was using, and ffdshow was not using xvid final to process the video. I believe i can make it work in 98 now using mediacoder. No need to since it works on xp but i hate to not have something working. I am determined to figure out how to fix it up in 98 LoL. Thanks for all the suggestions admin person.
I am also still interested in getting this to work in Ubantu, if you have any ideas i would appreciate it. Now i am beta testing windows 7 also. May try to fiddle around with that os also.
Xp is actually fast on this system and i like it more than i had in the past. I changed it all to look pretty much like 98 LoL again. Still stinky over the security issues though. I went through the registry and shut off raw sockets so thats out the way. WMV fix for the scripting, got my old firewall to work with it also. Disabled WS scripting, installed a worm watcher, file monitor also. Have a registry watcher installed. i think im good so far.
PS. i used a file outputted from vidrop that runs on it to look at the specs. Thats where i found out where i was going wrong.
Old 12th Mar 2009, 2:02 am
Cool. So you've managed to get it working now?
Old 23rd Mar 2009, 10:58 pm
fliperover:
I'm staggered that you're still running 98. I thought I was in the dark ages for running my webserver on Win 2000.
I fail to understand how Windows 98, which is essentially a DPMI shell, could possibly be more secure than any NT OS. I've been using Server 2003 for nearly 6 years now and have never had ANY trouble with it. I never liked XP much, either. But any NTOS can be neutered to be safe. I don't know about Vista because I haven't tried it. Probably never will. I might have a play with Windows 7 (aka Vista SP3) when I get around to it.
Anyhow, I was going to point you to viDrop but somebody else beat me to it.
Help with avi to asf conversion kimig1 Video related 12 25th Sep 2008 4:19 am
Torrent Conversion to AMV mila Video related 2 22nd Mar 2007 3:39 pm
AMV Conversion Help minto1959 Video related 5 12th Feb 2007 6:22 pm
conversion of .mov to .amv files dhiren Video related 10 18th Jul 2006 2:49 am
