[solved] Helpless idiot in need of help
Old 24th Mar 2009, 12:28 pm
Default [solved] Helpless idiot in need of help
So I bought an Ipod nano clone called diel-roc 16GB
http://www.e-ville.hk/fi/product/view/?id=1470
So first how do I know which firmware version do I need to download?
My system settings say that my current is: bksc2025101_2
Second: Do I need to upgrade the firmware to be able to put themes to my player? Can the themes make the player show the covers in the ID3 tag?
Can the themes make my menus different (my current menu is horrible, you have to jump between a thousand folders to change the album youre listening to and I would like to have "Ipod menutype" where you could search by album or artist?
Old 24th Mar 2009, 11:18 pm
i am afraid you can not update the firmware
you can not add themes
these are generic players with no support unless DIEL has an updates firmware which is very unlikely
the players you have does not sort music in any way im afraid, its just lists them
so you have a player that will only do what it originally came with, these things are basic and old now and are ipod in external looks only
you wont get album art
you wont get themes
thiese players are the older gen,if you want things like album art and proper music sorting then the device you have will NEVER DO THAT
sorry
Old 25th Mar 2009, 7:02 am
Default Re: Helpless idiot in need of help
Too bad..
Well thanks for the answer anyway =)
Please help an idiot with Ramos 960 software Snowman Support and How To 3 4th Jan 2009 7:34 am
idiot question about the ipod connector cyberlizard Support and How To 2 24th Dec 2008 3:14 am
Idiot questions from a newby Tantalo Support and How To 2 21st Jul 2006 1:11 am
