MP4 help.....about firmware
Old 4th Apr 2009, 3:28 am
Default MP4 help.....about firmware
I have this mp4 Blueberry EXIT BC 8 GB player
I need some help about firmware upgrade and proper conveter (wich one to use)??
Old 4th Apr 2009, 10:14 am
You have a Rockchip 27xx series player, make a backup of your firmware first!
look here:-
http://mympxplayer.org/firmware-extr...s-vt10856.html
use viDrop to convert your videos, you will find most should play without conversion, but not all videos.
Old 6th Apr 2009, 5:22 am
Default Re: MP4 help.....about firmware
When i insert subtitle using ViDrop....is it possible when you use "keep aspect" or "add borders" for resize method to put subtitle under the video ???
