Writing into memory problem
Old 7th Apr 2009, 11:16 am
Default Writing into memory problem
Hi everyone,
please could anyone help me with fixing memory related problem of my MP3 player?
My player is: Rockchip RK 2608A, BA 7165 0849
with Samsung K9LBG08UOM.
It is a 4GB memory that I checked and is not hacked. After I upload any files they get later corrupted and cannot be read. It seems like it writes some new data over the old ones (when pics are uploaded they are overlapped when opened).
I tried chkdsk and the result - cannot write in FAT. Formatting doesn't help.
Anyone knows what causes this problem?
Old 19th Apr 2009, 12:28 am
Is your player formatted with FAT, FAT32 or NTFS file system?
I would suggest to try FAT32 if it's currently FAT.
If your player is formatted with FAT32, try formatting it in NTFS instead.
Let us know if that helps....
Old 19th Apr 2009, 5:32 am
No player I know of can read NTFS, except maybe Microsoft's Zune.
NTFS on flash is also a bad idea, because it's journalled and the flash only has several thousand endurance per block.
Old 20th Apr 2009, 1:21 am
Default Re: Writing into memory problem
The memory was formatted with FAT32. I was also trying NTFS but it couldn't go through. The problem was that even files larger than 5MB became easily corrupted...I had no luck so I returned the player to China.
Thank you for your help.
V
4GB iTouch copy with memory problem - full memory dobo_d1 Support and How To 3 2nd Jun 2008 8:02 am
Problem with memory cmb9212 Support and How To 1 25th Jul 2007 8:51 pm
problem of memory sohih Dead Players 1 23rd Apr 2007 9:10 am
Memory problem SayNoMore Support and How To 3 1st Apr 2007 12:52 am
memory problem rjsoni21 Bad sellers/Blacklist 2 31st Jan 2007 11:51 pm
