How to extract the firmware of this MP4 Player?
Old 25th Apr 2009, 5:56 am
Default How to extract the firmware of this MP4 Player?
I've recently bought a MP4 Player, model MF-MS5 (2GB), by Powerpack, FM version 9.5.54
And I would like to know what tool that enables me to extract the firmware (for backup and modding) and what tool enables me to modify it. If there is some another firmware I could install on it, plz lemme know.
Specifications:
MP4 - MF-MS 5
Old 25th Apr 2009, 9:29 pm
Default Re: How to extract the firmware of this MP4 Player?
s1res 4.0
Don't try any other firmware, it will likely make your device unusable.
Old 26th Apr 2009, 6:48 am
Hmm, I downloaded s1res 4.1, so, I select the Access method to GIVEIO(v9-compatible), choose the letter drive of my MP4 and when it tries to read the firmware, it just gives me an error "the limit time of semaphore ended".
What should I do?
Old 26th Apr 2009, 6:21 pm
That is a USB problem. Try another computer.
Old 26th Apr 2009, 7:01 pm
=S I tried it on my Desktop, in all ports and I got the same msg as of the Laptop.
Old 27th Apr 2009, 6:59 am
i have the same problem!
How do I extract firmware from my player louigi600 Support and How To 0 7th Dec 2009 6:13 am
i extract my mp4 player firmware need HELP cchl2005 Support and How To 3 28th Aug 2007 4:17 pm
Rockship firmware, how to extract from this player xumber General Discussion 2 18th May 2007 4:48 pm
can't extract the firmware of my player rapfi Support and How To 2 21st Mar 2007 4:53 am
Mp4 player cannot extract firmware katuga118 Mods and Themes 7 19th Jan 2007 11:07 am
