Before I upload firmware, need help (RK2606A)
http://img.photobucket.com/albums/v2...Picture020.jpg
Hi, new here. I can't find where to upload my firmware but I figure I should check everything is ok before I do. This is a 2GB Mp4 USB 2.0 Mini video player. Has FM and miniSD slot and mic. I took it apart and it's an RK2606A. But I could not find any numbers on the board or anywhere else. I found some numbers on either side of the screen. KGM312B1 1101-2 D2FYRI -1MK A-KRC6A131 73 10-W And on the other side W-KLM312B11. A-060911/B1 Sorry I can't find anymore, but I can't open the player all the way because there are wires connected from the front panel to the back panel. The player came with firmware on the CD, which I've tested and it works. Version on the player is: Ver: 00.00.0002 Date: 2006-11-25 So as that firmware works I figured I should upload it but I want to make sure I've got enough info first. Thanks, |
hi antique666
That's plenty of info, thanks. To upload your firmware go to this page:- http://www.mympxplayer.org/dload.php (you will need to be logged in) Then click on the drop down "Select a category", scroll down to "uploads by members" and press enter, then at the top of the screen you will see an "Upload" button, http://mympxplayer.org/templates/fis..._pa_upload.gif then just click on it to go to the upload screen, and please remember to include a photo of your player. |
Re: Before I upload firmware, need help (RK2606A)
Thanks a lot, Knob
I've uploaded it now so I hope it helps some other people Thanks, |
| All times are GMT -7. The time now is 6:12 am. |
