Need help!
Old 17th May 2009, 7:00 pm
Default Need help!
Hi guys,
I posted my complete problems list in another thread, but I would like to get this problem fixed first..as I believe it's the cause of all my trouble.
My MP3 player displays 2 seperate drives when I use the MP3 Disc tool to remove the memory hack.. Drive F: & Drive J: appear when I complete step 1 in the guide.
Drive F: appears with 17.2 mb and in FAT format
Drive J: appears with 3.97GB and in FAT32 format
If I complete the Partition and encryption process only 1 drive appears. F:
& it's in FAT32
I need drive J: because it's the larger partition. If I format drive F: there is no option for FAT..only FAT32 if I do the format Drive F: properties tells me I have 7.87 GB again...HACK is still in place. & my MP3 player has 0% of 00 m used...
So I guess my qustion is how do I get drive J: & F: together as 1 in FAT which I think is what I need to do in order to get more them 17.2 mb of usable memory..
This is confusing..& I apologize for the mess..Hopefully a pro and hep me out on this..
PS. I've already tried RUN-CMD- typed format F:/fs:Fat but it comes back saying F: is too large for FAT if I try to change drive J: to FAT32 it comes back with Drive J: is too large for FAT32..
Somehow I need to combine both Drives..
Any ideas>>>?????????
Old 18th May 2009, 7:45 pm
Default Re: Need help!
-- ignore this doublepost --
Old 18th May 2009, 7:47 pm
Setup -> Online Device -> Normal Only
Old 18th May 2009, 8:23 pm
Sorry for the double post..but I wan't getting much user to user input on the other thread...+ the other one is a mess of repost by me adding different stages of my problems... If you like you can delete this one from the server & I'll refrain from starting any new ones.
Old 25th May 2009, 1:13 am
yes that's easy enough...but like I already said. My player has 2 partitions. 1 is in FAT & the other is in FAT32.. I want to get both in the same format so I can use the thing!!
Windows won't let me.. What should I do besides heaving these in the garbage??
FTANL
Old 27th Mar 2010, 6:32 am
Follow this link
Remove Memory Hack (HOW I DID IT)
