How do i edit firmware
Old 16th Jun 2009, 11:52 am
Default How do i edit firmware
i would like to know how to edit my mp4 player's firmware
it looks like this(sorry for bad pictures)
the mp4 board id
the samsung chip
the other chip
i would like to know what type of mp4 i have if its rockchip action or sigmatel
and also i cant extract my firmware with s1res or s1fwx
the firmware is(or what it shows:mp3 player
QSD_1307
2008-05-21
9.1.54
2005-01-09
thanx in advance for helping
Old 17th Jun 2009, 12:40 am
Actions AK1025 controller, 4Gbyte SAMSUNG NAND flash.
s1res v4.1 should work in extracting the firmware from it, if it doesn't work what error are you getting?
Old 19th Jun 2009, 4:37 pm
it says ERROR: no flash chip detected
Old 20th Jun 2009, 1:26 am
Please post screenshots of the appropriate error messages and detail the process you attempted.
Old 20th Jun 2009, 5:55 am
here is all the stepsa i did
and this is the error
and the steps are i plug in mp4 wait for everything
go to s1res 4.1 and click import firmware
then i i click next and yeah i get that error
Old 20th Jun 2009, 8:33 pm
Run s1giveio v1.4 (download here: RapidShare: Easy Filehosting)
Then run the following commands and post the log of the resulting transcript.
Code:
o 2 8
o 28 6
o 2a ff
o 2a 70
d 8000 1
o 2a 90
o 0 22
d 8000 4
q
It should look something like this, though the returned values may be slightly different:
Code:
s1giveio v1.4 - some small debug console to access the players hardware
copyright (c)2008 wiRe <wiRe@gmx.net> - http://www.s1mp3.de/ - FREEWARE
give access to the device...
open device: \\.\H:
giveio version: 3.1
v9-device detected
use command '?' for help!
-o 2 8
-o 28 6
-o 2a ff
-o 2a 70
-d 8000 1
8000    C0                                                    └
-o 2a 90
-o 0 22
-d 8000 4
8000    EC D5 55 25                                           ∞╒U%
-q
What we are especially interested in are the last 4 values (EC D5 55 25) since they are the ID of the flash chip. The problem you are experiencing may be because s1res v4.1 doesn't recognize the ID of your flash.
Is it possible to edit firmware on this player? TK31 Support and How To 6 21st Jun 2009 5:05 am
How to see and edit the firmware folder? Unkuiri Support and How To 0 25th Jan 2009 7:56 pm
Need software to edit .BIN firmware putera_aspura91 Firmware 0 12th Dec 2008 4:36 pm
How do you edit a full firmware? Jordinho Support and How To 0 8th Jul 2007 6:07 pm
How to edit firmware? bsaylors Support and How To 1 5th Aug 2006 8:11 pm
