Help (dv mp4 mp5 player buttons hang problem)
5 Attachment(s)
you can see this mp5 player in the attach images
below are details big chip: ATJ2137N (ACTION) Memory chip: SAMSUNG K4S641632K-UC60 2GB AND OTHER LETTERS :ZA31TBBC3G ZX-8016R-TLSK-T-V2.3 20090408 -------------------------------------------------------------------------------------- NOW HERES THE PROBLEM I AM FACING WITH THIS DV MP4 MP5 THE PLAYER IS POWERING UP AND CAN CONNECT IN USB MODE AND SHOWS THE STORAGE AND IN SIMPLE MODE SHOWS THE MENU.THE POWER BUTTONS DOES TURN ON THE DEVICE BUT IS NOT ABLE TO TURN IT OFF.AND RESET BUTTON WORKS AND HOLD SWITCH IS ALSO WORKING FINE.BUT THE BUTTON A,B,M,OK,LEFT,RIGHT,UP,DOWN DOES NOT WORK.BY PRESSING THESE BUTTONS THE DEVICE TURNS ON FROM STANDBYMODE BUT THE MENU DOES NOT MOVE AND.ALTHOUGH THE SYSTEM IS NOT HANG IT SHOWS TIME AND MYMUSIC ICON KEEP ON ANIMATING BUT BUTTONS WONT MOVE THROUGH THE MENU ITEMS. PLEASE HELP ME IN SORTING OUT THE PROBLEM ANYONE FACING THE SAME PROBLEM PLEASE SHARE WITHUS |
Are you in Hold mode?
no i am not in hold mode indeed the hold mode button was working fine for me but i have flashed it with wrong firmware so now the screen has become white but i can hear sounds by pressing buttons which means my buttons were ok (problem was in firmware)now i need exact firmware for this model.
There's a ZX-8016R firmware on mydigit.cn but I can't download it. Maybe you'll be able to figure out how.
thanks i will try to download it.are u sure that this firmware will match with my action atj2173n chipset.
wow they ripped the menu off Sunplus players??! :|
| All times are GMT -7. The time now is 1:02 pm. |
