USB cable broken
Old 8th Jul 2009, 5:47 am
Default USB cable broken
Hello
I own a Brondi MP4, the original cable is broken, it is a strange mini USB Cable with a
mini USB connector with 4 pins, someone knows as the wire are connected in the cable ?
yours
Alberto
Old 8th Jul 2009, 1:00 pm
Have a look at the USB cables available for MP4 players on eBay. Here --> mp4 usb cables on eBay.
I think it should have the one you are after. It'll be cheaper to get a new one than to get it fixed etc...
Old 9th Jul 2009, 2:07 am
Thank you for the suggestion, I asked for a layout just to be sure to buy the right cable, it isn't a normal mini USB connector
yours
Alberto
Samsung yp-z5 USB data Cable//losing usb cable P@inKuler Support and How To 2 5th Feb 2009 1:38 pm
usb cable for mp4 eltocado Support and How To 3 13th Apr 2008 1:09 am
USB cable Zephyron Support and How To 3 9th Mar 2007 4:30 pm
Fixing a broken USB cable optik Support and How To 2 29th Dec 2006 3:23 am
Usb Cable eldiablo04 General Discussion 4 27th Jul 2006 10:12 am
