My RK27SDK wont connect properly PLEASE HELP
Old 7th Sep 2009, 8:12 pm
Unhappy My RK27SDK wont connect properly PLEASE HELP
Hi,
I have just bought the RK27SDK,
Major version ID : 1.2
Hardware ID: 080422
Local memory size 3.84G (total)
I am having the problem that when i connect it to my desktop it shows a USB and a PC notifying me that it is connected to my PC. Then it quickly goes to a charging icon and there is not recognition of the player connected or being connected ...
Like i have read in most threads from this site and the previous site MyMPxPlayer.org i thought it may have been the cable itself. So i conneted it to my laptop and straight away with no ifs or buts it connects and recognises, within 30 seconds im able to transfer music.
I then decided to install the driver CD onto my desktop thinking that maybe that might be the problem. I have AVG installed as my anti-virus and its fully updated, when i install the MP3 Playe Utility 3.68 AVG prompts me that a Trojan is trying to activate???
You have my specs and my problem, PLEASE HELP im going mad reading threads and i just keep running into dead ends...
Old 8th Sep 2009, 4:45 am
MP3 Player Utility 3.68 is no use for Rockchip players.
You need to install the rk27usb.sys driver on the other computer. you can download here:- Download
Just install the driver from the application's folder - don't use the repair tool it's for DEAD players only and your player is ok your pc just needs the driver.
If this doesn't work then there is a problem with your pc usb socket - try another - good luck, hope this works.
Old 8th Sep 2009, 4:05 pm
Thank you so much knob, ill give that a go now and report back.
Old 8th Sep 2009, 4:39 pm
Default cant continue with driver
hey sorry guy but can someone please tell me how to install the rockusb27.inf because i have selected it manually through the add hardware wizzard but when i select the file manually i get a blank screen.
I have added a screenshot of where i cant go any further.
Cheers again
Old 23rd Sep 2009, 9:20 am
Hello i have exact the same problem Vista USB
Please help
thk Jan
Old 25th Apr 2011, 5:49 pm
Default same prob here window 7
i have windows 7 does anyone have the driver for the rk27sdk the one listed above it for the wrong model...
Tags
4gb, mp5, no conmection, rk27sdk, wont connect
RK27SDk player cant connect to computer kage Support and How To 4 13th Jan 2011 3:31 pm
[solved] Fake iPod Nano, works but wont connect on XP - 'unknown device' trebor_69 Dead Players 4 23rd Nov 2009 3:06 am
RK27SDK, connect problem - "Not formatted, do u want format?" Musy Support and How To 2 22nd Oct 2009 2:34 am
won't charge properly Podder Support and How To 3 1st Mar 2007 6:59 am
wont connect to me computer red Support and How To 1 27th Jun 2006 3:15 am
