Onda VX767LE Buttons Problem
Old 14th Sep 2009, 7:01 pm
Default Onda VX767LE Buttons Problem
Hi everyone,
I got the Onda VX767LE mostly to read e-books and used the >> and << buttons to navigate in text files a lot because the preset auto browse timing (10 sec, 15 sec, 20 sec...etc.) do not work for me. After 6 months (purchased in March) the >> and << buttons on the upper right are worn down - they don't click, cannot control which way it moves and get stuck a lot. The + and - buttons on the upper left which were used not nearly as much are also beginning to have the same problem. It has come to the point now that it is very difficult to go to a file because the scrolling will go crazy and cannot be stopped, and once in a file you can hardly move forward or even set the auto browse anymore.
This is apparently a hardware issue, but I thought I'd check around to see if anyone has any experience getting this fixed before sending it to Onda for repair. I fixed the on/off button on my Kodak digital camera myself but when I looked there is no screw or any obvious way to open up the VX767LE. Besides, I wonder if opening the player will void the warranty. Can anyone help? Thank you.
Help (dv mp4 mp5 player buttons hang problem) shades Support and How To 5 2nd Jul 2009 12:47 am
problem with onda VX858 clone Matsca Dead Players 4 14th Mar 2009 1:31 pm
Dead Onda-Clone. Buttons/touchscreen doesn't work Alexsk8 Dead Players 5 22nd Jul 2008 12:06 am
Problem with buttons and USB conection Upa Mpx! Support and How To 1 13th Apr 2007 3:02 am
problem with menu and play buttons and a firmware q gam3r General Discussion 2 11th Oct 2006 8:51 am
